Challenges Wiring Through My 355 AC Radar Arch
gmac98004
Vessel Info: Proud new owner - '98 355 Aft Cabin "Invictus"
6BT5.9M 210hp
Formerly - 1986 - 30' Newport MKIII
Has thanked: 451 times
Been thanked: 12 times
Postby gmac98004 » June 16th, 2020, 11:38 am
Hello Team!
I'm in the process of wiring a new XM antenna through the radar arch and down to the crazy angled stereo cabinet pedestal in the STBD cabin.
After taking off the access panel on the radar arch, I've spent an embarrassing number of hours trying to find a wiring path to that pedestal. Many panels have been removed with no luck!
So two questions for the group:
1. Any great suggestions on a wiring snake that can turn that sharp corner on the radar arch successfully?
2. Any suggestions at all on the pathway for wiring to that stereo cabinet from the STBD radar arch panel?
Thanks everyone for the help!
Take Care, Greg
Been thanked: 490 times
Re: Challenges Wiring Through My 355 AC Radar Arch
Postby waybomb » June 16th, 2020, 12:27 pm
I can't help with your dilemma, but when you do pull pull an extra cable for future pulls.
Postby tomschauer » June 16th, 2020, 1:03 pm
Pull out the cubby shelves on the port side of the bridge. Pulling wire from there to the top of the arch is pretty easy. In there you will see a major bundle of wires that go down to the cabin and engine compartment. If no one else messed with it, everything will be wire tied together and not make it an easy fish. Use a round plastic or fiberglass fish tape paired with a whole lot of patience.
Postby km1125 » June 16th, 2020, 1:30 pm
If there's a loose wire along with a bundle, you can use that to pull through a temporary pull wire. Disconnect it from whatever it's used for and use it to pull the temporary pull wire. Then pull that back out when it's attached to the loose wire along with your new wire (and maybe even a new pull rope for future use).
Postby g36 » June 17th, 2020, 12:59 pm
Another 5 minute job. Can I get a amen. :-O
gmac98004
6BT5.9M 210hp
Postby gmac98004 » June 18th, 2020, 11:00 pm
Thanks everyone! I'll throw some additional effort at this and see what I can come up with.
Take Care, Greg
