RPM GAUGE PROBLEM
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
RPM GAUGE PROBLEM
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: RPM GAUGE PROBLEM
The internal contacts on the selector switch tend to corrode over time and cause erratic readings. As a temporary measure, note the position of the switch, then rotate it back and forth several times. This helps clean the contacts in the switch. Note that some switches have to be pushed in slightly first before they will rotate so don't force it. Return the switch to the original position, then run the engine to see if that helped.
If it works, the fix can last for years or not long at all. Chances are it'll happen again as it's an indication that the components inside the gauge are starting to degrade and you should budget for new replacements.
Keep us posted
- RWS
RGrew176 wrote:Source of the post You could pull the tach and check if there is a knob on the backside of the tach. If there is there would be settings for 4 cyl, 6 cyl 8 cyl and so on. On my last boat the tach's were off and I pulled both of them. They were set on the O/B (outboard) setting. Moved both of them to the 8 cyl setting and all was well.
Thank you.
- RWS
Viper wrote:Source of the post Ya check the rotary switch as Rick mentioned to ensure it is set properly. If it hasn't been touched and this just started happening, you likely have internal gauge issues or a problem with the wiring; bad connection, corrosion, etc.
Keep us posted
Thank you sir.
