New GPS/chartplotter install
- iceman3500
- Vessel Info: 1987 Carver 3207
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: New GPS/chartplotter install
The best location for a transducer is ahead of the props in 'clean' water. Your plan to replace an unused thru hull should work very well. If available a bronze 'ducer is a safer choice than plastic as it won't crack if struck.
SeaDragon
- iceman3500
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
I just did what you are trying to do. In the 77' Mariner, Carver actually made a box in the hull that is filled with antifreeze and they mounted a thru-hull transducer inside the box. I removed their non working transducer and out in mine for my Eagle 480 DF. The problem came because my transducer would not fit. I had to cut the fiberglass hole bigger and make a new custom cover. It was actually petty easy. Routing the wire was pretty simple using a fish tape and just following the route they took before.
If you don't have a box premade, just build one on the bottom. It should be ~6"x6". I mounted the transducer to the cover and it just hangs in the antifreeze. It shoots through the hull nicely because Carver has the spot in mid hull thin (they removed the balsa core in this one spot), just for the transducer.
Steve
- iceman3500
- Been thanked: 490 times
- Seif911
- Captain
Steve
