Depth Sounder/ Fish Finder Advice
Not that I really need a fish finder but the newer chirp stuff does seem to give a pretty nice view of the bottom. Looking to purchase a cp100 sounder http://www.raymarine.com/view/?id=8069 combined with a CPT-110 transducer.
That being said I will not install until end of season haul out as I do need to drill the hull for transducer installation unless I can work out a deal with my haul out guy such as pull her out a few feet, I drill and install and plop her back in.
Any comments suggestions appreciated before I plop down another $700.
Re: Depth Sounder/ Fish Finder Advice
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- lewistodd
- Vessel Info: Dedicated to the conservation, protection, and enhancement of fish, wildlife, and plants, as well as the habitats that support them.
- Has thanked: 1 time
The mount is easy and quick to install or remove before or after use. On the water, the mount holds the unit very rigidly, i.e., it does not shake or shift when on-plane or in rough waters because of the rubber ball. http://fishvantage.com With that, you do not need to tighten the clamp as much as you may think for it not to move. So far, driving 75-plus miles per hour or cutting three-foot rollers has not shifted or slipped the mounted unit.
I've used several RAM Mounts over the years, and they continue to perform well for me. Even if you don't NEED it, I'd recommend getting one for the ability to fine-tune your viewing angle. Also, you will get aware of the fishfinder and how it works.
