In-hull transducer / 03 Carver 444 or similar
PhotoHog
Vessel Info: 2003 Carver 444 Extended Salon (purchased late 2021)
Cummins 370s
Freshwater - for now.
Been thanked: 3 times
Postby PhotoHog » April 24th, 2023, 9:32 am
Hey all,
I want to install a Garmin P79S in hull transducer on my 03 444. In looking at the specs it says not to install on cored hull or a hull that's over 5/8" thick,
I know these hulls have cored sides but not bottom, so that should be fine. Does anyone know the thickness? And has anyone installed a similar unit (I think most companies sell a version of the P79S) and had any performance issues?
Thanks in advance
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: In-hull transducer / 03 Carver 444 or similar
Postby Cooler » April 24th, 2023, 11:35 am
I believe your hull in that area is going to be at least 2" thick. The basis for this is a conversation I had with Carver when I bought my Mariner 6 years ago. They had pulled the build log and disclosed a minimum 2" depth to the bottom. Having said that, my depth gauge transducer is installed inside hull at about midship. I have no issues with my depth readings. They are normally very similar to the depth reading on my Garmin with the transducer hung outside of hull on the transom. Good luck! You may want to check your owners manual for core material. Carver used coremat on a number of models. 8-) er
Cooler By The Lake
