Plumbing in 2000 374 Voyager.
- erpeldingj
- Vessel Info: 2000 374 Voyager
- Has thanked: 3 times
- Iceagetech
- Vessel Info: 1987 Carver 2827 Voyager
Twin Crusader 220HP Inboards - Location: Wabasha, MN
- Has thanked: 2 times
- Been thanked: 11 times
Re: Plumbing in 2000 374 Voyager.
- Been thanked: 490 times
- erpeldingj
- mjk1040
- Been thanked: 248 times
- Has thanked: 602 times
erpeldingj wrote:Source of the post I need to replace some fittings in the red and blue pex lines going to my sinks. Lots of leaks on a boat that sat for a few years. Regular 1/2 in fittings seem too big (shark bite and such). Any suggestions?
If you have the same lines as I do, this has worked for me.......if there is some slack (extra length) you can snip a 1/4" of the ends with one of those pex tubing cutters and reattach....gets to a new spot on the line......
When I was researching, all that grey tubing had recalls because of leaks. They used it in a lot of homes and mobile homes and it caused a lot of damage from leaks. There was a class action lawsuit and you could get reimbursed for replacing it, but it had to be "inaccessible". On a boat with all the hatches and various access points, I didn't qualify. If you had a home and had to cut drywall to replace, you did qualify.
bud37 wrote:Source of the post....if there is some slack (extra length) you can snip a 1/4" of the ends with one of those pex tubing cutters and reattach....gets to a new spot on the line.....
++1
The fittings themselves rarely fail. What does cause problems after a while, especially with areas that get removed a lot like those at hot water heaters is the contact surface of the tubing. As mentioned above, if you cut some back, it provides a new surface for a good seal. If that doesn't work, then the cut isn't straight, there is stress on the fitting, or the fitting is bad.
I wouldn't stress too much about the Qest plumbing. Every type of plumbing will leak eventually. The key here is don't leave your pump on or the dock side water on when you're away from the boat.
