Bad AC water pump. Any info?
grimace
Vessel Info: 1992 Carver 280 Aft Cabin
Postby grimace » September 24th, 2020, 1:36 pm
Hi All. Question about Air Conditioning pump. I have a 1992 Carver 28 aft cabin and my AC isn't working. Have been told the fresh water pump pictured here is an old model and is dangerous as they catch fire. Does anyone have knowledge about this pump? Is it dangerous? Can it be repaired? What's a good replacement option? Thanks.
Re: Bad AC water pump. Any info?
Postby Midnightsun » September 24th, 2020, 1:52 pm
I have had a cal pump in another boat, never heard of them catching on fire. They are the quietest pumps I know of. Forget repair, buy a new one. Not sure what GPH you have. http://www.calpumpshop.com/CalMarine-MS ... p-116.html
Postby km1125 » September 24th, 2020, 6:31 pm
What does or doesn't it do? Have you taken the pump side apart to check the impeller to see if it's all gummed up with something?
Been thanked: 491 times
Postby waybomb » September 24th, 2020, 7:14 pm
Is that discharge pipe busted?
grimace
Postby grimace » September 24th, 2020, 11:33 pm
I'm not sure if the discharge is broken or just unscrewed. Either way I think there is enough to still connect.
Been thanked: 470 times
Postby RGrew176 » September 30th, 2020, 9:00 am
You're going to need a 500 GPH pump at minimum.
