Suggestions for replacement of hot water tank
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
I am hoping someone can provide some "tricks of the trade" so I can avoid any problems.
Thanks.
Re: Suggestions for replacement of hot water tank
Many are just leaking from the overtemp/overpressure safety valve and that can be cleaned or replaced.
As to replacing them... they are pretty straight forward as long as it fits out of the hatch.
Note that if it has a heat exchanger for the engine you're going to be dealing with antifreeze too. Make sure there's no pressure in the cooling system on that side before you take the clamps and hoses off at the heat exchanger (and that the engine is cool).
Obviously, shut off power and depressurize the potable system before you begin.
- tgebler
- Been thanked: 654 times
Take pictures with your phone beforehand if in doubt where stuff goes.
