86 Mariner 3697 AC water pump
- MrMojoRisin
- Vessel Info: 1986 Carver Mariner 3697
- Has thanked: 32 times
Also, how do i confirm that this pump is the original pump that came on the boat? Reson for the qustion is a buddy of mine has a 34' Silverton with a single AC unit and the pump he just replaced on his was 500gph. The one in my boat currently is only 300gph and, if i'm not mistaken, is supplying water to two AC units.
I'll try to attach a picture of my existing pump.
Is that enough volume for two AC units?
Boat is approx 2 hours from home, in storage, but they are winterizing tomorrow so i'm going up this weekend to grab the batteries and take some additional pics and measurements. White there I was going to pull the pump and check the strainer while i'm at it.
Eric
2012 Larson FX1850
- Been thanked: 654 times
Re: 86 Mariner 3697 AC water pump
- Been thanked: 490 times
- MrMojoRisin
I only see one breaker for the A/C water pump, but do have 2 breakers for A/C units. So i'm assuming one pump feeds both. Since i'm going to be there anyway this weekend, i may just try to pull the pump to take home and see if it works at all. This might be a project better pushed off till the boat is in the water and i can go through a full startup to troubleshoot. But if i take the pump off now, and it doesn't work at all, i can go ahead and get the replacement ordered.
waybomb wrote:Source of the post I believe the main cabin is a 16000 btu and the one under the bed is 9000. 25000 btu/24000 btu x 1.5 x 60=187.5 gph. So 300 gpm should be correct.
MarinAire makes a 500 gph and a 600gph in the same size pump housing/configuration. It has a 3/4" inlet vs a 1/2" on the 300. I'll check this weekend if the inlet on my existing pump has a 3/4" inlet. Too hard to tell from my pics. Would it be harmful to the system if i were to upgrade the pump to the 500gph as long as my circuitry can handle the requirements?>
Thanks again for the input.
Eric
2012 Larson FX1850
Disassemble the impeller section of the pump. There could just be debris in there preventing the impeller from turning. They are frequently just magnetically-coupled to the motor, so it doesn't take a lot to stop it from turning.
Any larger pump would be fine, but if you go too big you're just going to be restricting the flow anyways with the smaller hose sizes.
When either ac unit is on, the pump is switched on with the relays in that box.
Easiest way to get to it is pull the door off the cabinet and lay down on the floor. In fact, the only way. Unless you had the sink out like I did. I also installed a larger sink so I had a bigger sink hole!
You don't need a bigger pump.
You can buy just a new head if the magnetic part is shot.
- Has thanked: 602 times
The calculations are a good starting point IMO but remember they do not take into account all the hurdles encountered on different boats. Your friends boat may be a completely different install regarding hose lengths and head height issues, elbows. On one boat the theoretical may be fine, on another not nearly enough.
If the old pump was in there for years then it was probably fine. You really have to keep after maintenance with those systems, clear thru hull, clean filter, clean lines that are not old and kinked, open discharge thru hull port etc.
I don't believe you can damage anything with a larger pump, but as has been mentioned, the wiring has to be up to it.......really there is no advantage IMO.
Users browsing this forum: No registered users and 37 guests
