356 light switch
thp1957
Vessel Info: 2001 Carver 356
Cummins Diesels
356 light switch
Postby thp1957 » August 21st, 2018, 7:50 am
Hi, on the side of the galley cabinet that faces the booth there are to light switches (rocker type). The one on the right turns on an over head light. Can’t figure out what the one on the left turns on, other than a small green indicator light mounted underneath it.
Any ideas?
Thanks. :usa:
Re: 356 light switch
Postby bud37 » August 21st, 2018, 8:26 am
Engine room light....
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » August 21st, 2018, 9:58 am
Don't you have 4 switches on that cabinet?
In case it is burned out, the engine room light is directly under the companionway steps. You really have to stick your head in the bilge and look up to see it.
thp1957
Cummins Diesels
Postby thp1957 » August 21st, 2018, 2:08 pm
Ahhh....thanks. That helps. :worthy:
Return to “Electrical”
