Leave charger on or not?
- bobcinga
- Vessel Info: 2006 CMY 41
- Been thanked: 4 times
Oh one more thing. No idea what setting the charger is set to related to lead acid, gel, or AGM. Not sure what CCharles or Carver was thinking, but the switch to change the setting is on the back of the charger and it is mounted to the back port bulkhead with about 3 inches between muffler and unit. No way to get to it that I can see.
- mjk1040
- Been thanked: 248 times
Re: Leave charger on or not?
- Has thanked: 603 times
If so then I see no reason to worry about it, they are designed for this....but myself, I personally shut everything off when we leave the boat. I wouldn't worry about cold batteries in the bilge , fully charged we leave them all winter at - temps with no charger on them and they are fine.
- Been thanked: 654 times
I believe the 5000 series comes set from factory to the GEL charge curve. This may have been changed at Carver though prior to the install. The GEL curve however while set to a charge voltage just slightly below the lead acid curve, both the GEL and lead acid setting have the same float voltage.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
FYI, NOCO recently came out with a very compact maintenance charger using the latest tech. These are great for mounting in various toys. https://no.co/genius2d- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
While in the water, I like them on charge for reasons discussed. This was also recommended to me by the Carver dealer when I bought my first boat. In the winter I also top up the charge and disconnect the neutrals an my Jet Boat and dinghy and have yet to have an issue. I have my Camaro on a battery maintainer all winter in the garage, due to the electrical systems on board.
With the temps up here in the winter, failure to top the batteries to a full charge, you run the risk of them freezing.
bobcinga wrote:Source of the post Oh one more thing. No idea what setting the charger is set to related to lead acid, gel, or AGM. Not sure what CCharles or Carver was thinking, but the switch to change the setting is on the back of the charger and it is mounted to the back port bulkhead with about 3 inches between muffler and unit. No way to get to it that I can see.
If you have the one with the analog gauge on the front, I am not so sure there is a switch back there, I just changed ours out ( 2001 model ) and there was no switch, It may have come set from the factory for particular charge profiles. Regardless you should still check your batteries with a volt meter after the charger has been on for a number of hours to see what voltage is being applied. If it is over 14 volts after say 24 hours charge, then the charger or something is off . I would be hesitant to leave a charger running at over 14 volts for long periods with no draw on it.....
I changed our because it would not get to float of 13,2 to 13.6 about....was always 14.2 at the lowest which I believe is the bulk charge number.
Users browsing this forum: Google Adsense [Bot] and 14 guests
