2004 466 MY Reading Light
wkeith
Vessel Info: 2004 Carver 466 Aft Cabin MY
Has thanked: 8 times
Been thanked: 14 times
Postby wkeith » May 27th, 2020, 2:13 pm
Hi to All,
Looking for the LED replacement bulb or fixture for the reading light above the forward stateroom bed.
Thanks in advance for the help.
Walter
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: 2004 466 MY Reading Light
Postby buster53 » May 27th, 2020, 10:36 pm
Hard to tell what kind of bulb is the fixture, but there is a LED replacement for just about any kind of bulb made. No need to replace the entire fixture.
My old sailboat had festoon bulbs that I replaced with LED bulbs I got from SuperbrightLED.com and my current Carver had a bunch of halogens and I found those at Amazon.
There are tons of places you can find LED bulbs. Google is your friend
wkeith
Postby wkeith » May 28th, 2020, 7:45 am
Thank you for your reply. I couldn't figure how to get to the bulb. The round portion of the fixture would separate from the the base, but then I wasn't sure how to get to the bulb for fear of breaking it.
Recently, I did change all my lights to LED's from Amazon and very pleased with results.
Thanks again.
Walter
Postby g36 » May 28th, 2020, 10:38 am
I have a couple in my 405. A few years ago I changed everything to led bulbs and fiddled with these for a bit and then just quit. I really never use them. If you do eventually fit the correct led bulb do you mind posting what it is?
Postby Midnightsun » May 28th, 2020, 12:37 pm
Plastic does get old and brittle so maybe consider changing the entire unit. https://www.superbrightleds.com/moreinf ... 1912/4296/
Postby tomschauer » May 28th, 2020, 1:49 pm
I believe it is an MR 16 bulb. Should be readily available. The come in 12 and 120 v, so make sure you get the 12v
wkeith
Postby wkeith » May 29th, 2020, 8:56 am
Thanks to all of you. I'll try the bulb if I can get the fixture apart, if not I'll look at the replacement.
Thanks again!
Walter
wkeith
Thanks again!
Walter
wkeith
Postby wkeith » June 4th, 2020, 3:05 pm
OK, finally got the bulb out by prying open with small screwdriver blade. The bulb is 12 volt, 5 watt, GE 58540. The replacement from Amazon is about $34 each.
Postby Midnightsun » June 4th, 2020, 3:27 pm
Couple of options.
Halogen like the original. https://www.bulbamerica.com/products/os ... light-bulb
LED replacement. https://www.superbrightleds.com/moreinf ... -car/2077/
Or search yourself for a BA9S T2.75 bulb.
Return to “Electrical”
