failure to launch.
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
failure to launch.
Postby rjr » July 5th, 2020, 5:47 pm
Could not start engines (Cat 3126s) today. Seems like it's electrical but don't know. Checked voltmeter before attempting to start. Batt 1 was at 11.9 and Batt 2 was bouncing around 14. When I turned key, the buzzer went all hinky, the indicator light for the windlass dimmed and engine did not turn over. Tried other engine - same result.
Switched to Batt 2. Same symptoms, same result. Switched to both. Same/same result.
I do not understand why motors would not start off Batt 2.
Odd that Batt 1 was at 11.9 since charger is functioning.
This whole thing is odd.
Thoughts and opinions welcome.
Re: failure to launch.
Postby Midnightsun » July 5th, 2020, 5:51 pm
Really sounds like just bad batteries IMHO.
Been thanked: 248 times
Postby mjk1040 » July 5th, 2020, 8:49 pm
Loose battery connections, bad grounds, corroded electrical lines and/or ground cables!
Postby Viper » July 5th, 2020, 8:56 pm
All the above! Check your connections at the batteries and engines, and have your batteries tested properly. Those Cats should fire up right away.
rjr
Vessel Info: 440 MY
Postby rjr » July 18th, 2020, 10:03 pm
Everybody is correct. Turns out there are breakers marked " one, gen and two" for the battery charger system. Breaker for "one" was popped. At that point, we knew there was a short but had no idea where. Reset breaker and battery charger did its thing. Batteries were fine next morning. Checked some connections and all appeared OK. Made mental note to put connections on list.
July 17th: Failure Part Two: this time Battery 2 was virtually dead, Battery 1 was at 12. Got engines started and then checked the breaker. Popped. Made mental note to check list.
Return to “Electrical”
Users browsing this forum: Google Adsense [Bot] and 14 guests
