House bank charging
- Been thanked: 654 times
Re: House bank charging
- Mkmohn
- Vessel Info: 2000 396
- Has thanked: 15 times
- Has thanked: 603 times
Mkmohn wrote:Source of the post My battery selectors are either on or off, all three are in the on position.
Could you take some pics of this set up....it may help..
- Lclifton
- Vessel Info: 1987 Carver Montego 2757
- Has thanked: 14 times
bud37 wrote:Source of the postLclifton wrote:Source of the post Mkmohn,
I realized it's fixed but.....
Just out of curiosity what position is your battery selector dial on? 1, 2, or all?
Any properly wired battery charger should charge regardless of the battery selector.....having said that , the engine/engines should only charge the batteries that are selected by the switch position.
If that is what you are thinking....Lclifton.....
I've been out of touch for several days...but I'd been struggling with how this all works. This is what happened to me,
(since the OP question is taken care of, I don't feel I'm hijacking the thread)
1. Put the dial on "All", everything charged fine.
2. Put the dial on "Off", nothing charged, DC volts showed zero.
My interpretation of the dial was that if it was in the "Off" position that the batteries were charging and I was basically using that charged power for house lights etc.
What I discovered was this;
My battery charger when hooked to shore power does not have a separate switch on the AC panel for "Battery Charger."
The battery charger is hooked into one labeled "receptacle."
So, to your point...the battery will indeed charge regardless of the position (except for Off?) but the charger must be on to do so. LOL. I had inadvertently turned it off and didn't realize it. I'm still learning but maybe this little venture (post) will help another new owner.
Users browsing this forum: Google Adsense [Bot] and 13 guests
