House bank addition to 310 Santego
Capn Crunch
Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard
Location: On the Mighty Columbia River in the Pacific Northwest
Has thanked: 87 times
Been thanked: 7 times
Postby Capn Crunch » October 25th, 2020, 11:27 am
Our Santego has 2 batteries only for engines and house combined, with a separate battery mounted on the bridge for i presume the windlass (not in use when we took possession of her)
Given space limitations where have others added a house bank on this model of Carver?
Thanks for your suggestions.
Mark
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: House bank addition to 310 Santego
Postby buster53 » October 25th, 2020, 2:42 pm
Do you have a genset with its own starting battery?
I have a 356 with only 2 starting/house batteries and a genset with it's own.
Anyway, my only suggestion, if you don't have the room for more, just get the biggest house battery that will fit. I have 2 deep cell, group 31's and a dedicated genset starting battery.
Capn Crunch
Postby Capn Crunch » October 25th, 2020, 3:46 pm
Hi Buster - no genset. On what we now refer to as the "Little Carver" we had a genset on the outermost port side and a battery, starboard had house bank of 2 batteries. New Carver has fuel tanks where those items were. The 2 engine batteries are at the lowest point of the bilge between the stringers - if I moved the bilge pump farther toward the transom I might be able to squeeze one more battery but iffy at best.
I'll be down to the boat tomorrow sometime, will try and get some pics.
Postby g36 » October 25th, 2020, 10:28 pm
Can you build a shelf to add additional batteries in the area?
Return to “Electrical”
