A/C Panel No Power
- Owensned
- Vessel Info: 2005 36 Motor Yacht
A/C Panel No Power
Switched cords on pigtail connection and A/C panel still not receiving any power while the other panel for all other electrical continued to work.
Thoughts?
Re: A/C Panel No Power
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
This actually happened to me last week.
Behind the breakers are your relays.
With shore power disconnected and genny off open the panel.
The relay on the right should be air con.
You should be able to push on the relay and watch the contacts move.
If one or two don't move they have weleded together.
A small screwdriver should separate them.
Then get in between all contacts with some sand paper.
Should be good then.
Only switch from shire to genny or vs versa with low loads.
No air or water heater on.
- Has thanked: 603 times
