AC breaker on 1995 Carver 325
- danideason503
- Vessel Info: 1995 Carver 325 Aft cabin
I own a 1995 carver aft cabin. I was using appliances on the port side and I believe I tripped the breaker. I went outside and made sure the shore power was working, turned switches off and on. On the panel, I only have a Shore #1 breaker which works supplying power to the starboard side (volts), however, the amps go slightly up for the port side and go back to 0.
GFCI outlets can’t be reset for port side but starboard side ones work fine. I unplugged everything, reset shore power and I’m having no luck. Does anyone know if there is an AC breaker hidden somewhere? I checked cabinets and all. Even under the stairs I see only battery switches. Please help if anyone knows this model well - owners manual is no help at all.
Carverlvr2
- Been thanked: 25 times
Re: AC breaker on 1995 Carver 325
- Has thanked: 602 times
Like has been said you will have to unplug all your appliances ( not just turn them off ), including the battery charger etc. Then reset, if the gfci is the cause of the no power then you have a fault to ground or neutral/appliance case. That will not necessarily trip a main breaker so be very careful here. If not comfortable call an electrician to have a look.
- Been thanked: 654 times
