Hull Shield
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
Hull Shield
Here’s the link:
https://info.boattest.com/e3t/Ctc/W1+11 ... BmC963bYl1
1979 Caravelle 18’
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Re: Hull Shield
To protect your running gear, you need to add one specifically for that which increases what you pay. In that case, the sound signal runs through the engine to the shaft, to the prop. Not sure if there are any long term issues for the engine. I haven’t seen any concerns with it, but still wonder about it.
Seems like a solution for salt water boats, not so sure on fresh water, because there isn’t nearly the same growth.
