I am the new (old) guy
Re: I am the new (old) guy
Postby Viper » September 11th, 2019, 7:51 am
Go to the holding tank pump out station and try that. Should be the same fitting. They often collapse holding tanks so maybe that will work. Don't know if it''ll hold it's shape but worth a shot as it's easy and readily available. Disconnect the hose from the tank to the fresh water pump and plug it off as Tom mentioned to prevent damaging the pump.
Postby tomschauer » September 11th, 2019, 10:38 am
Good idea on the pump out station for vacuum.
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Has thanked: 5 times
Been thanked: 7 times
Postby Youghster » September 18th, 2019, 10:32 am
Thanks for getting me in the right direction, I was set to go all goofy with tank squeezing. A little closer look and saw that the vent / overflow is about 2' above the tank, hmmm....maybe a little standpipe pressure. So I tried pumping a little water out of the tank and that seemed to help some, Then, thinking of the negative pressure suggestions, I put my thumb over the vent while the pump was running and voila, the tank bulge disappeared. The Boss says maybe I should not fill the tank so full, she is probably right.
I added a couple pics, but I am having a little trouble with the technicalities. I hope I am not smearing the forum finish.
Capn Crunch
Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard
Location: On the Mighty Columbia River in the Pacific Northwest
Has thanked: 87 times
Postby Capn Crunch » August 17th, 2020, 1:04 am
HI all, been a looong while since posting here - as most of our issues we solved after digging around a bit and talking to some old salty dogs :)
Our Montego has been doing well for us when there's no wind, a booger to return to the slip in a breeze.
All this is leading up to today and why I'm posting in this thread - We just put a deposit on a '95 310 Santego today! Sea trial tomorrow @ 5pm PST!!!!
Any valuable insider issues I should check out while during the trial? Is inboard's, haven't had a look yet, did Carver do V-drive, or direct? Still Borg/Warner - or did they switch vendors?
Also, running into a HIN issue - at some point the HIN was changed from a Carver to a "homemade" HIN, presumably cuz original HIN didn't conform to new as of 1984 standards? Make sense to anyone here?
Thanks for any input/advice!!
Mark
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » August 19th, 2020, 9:52 am
Capn - Carver did both direct and v-drives in 95. Mostly V. BW was the most popular vendor, but a few had Hurth. That HIN issue is troubling. You can not just change HIN, but in 95, the Carver protocol was compliant with standards, so that makes no sense to me. The number should be stamped into, or a plate attached to the transom area, under the swim platform. It may also be provided in the bilge to the stern. 95 was a a very good construction year for Carver. They did not have the wild swings in quality like some other brands, but some years are better than others. Good luck! 8-) er
Cooler By The Lake
