aluminium Fuel tank questions
- Has thanked: 603 times
We have been looking for a new boat for a while now and these tanks are probably the thing I look at the hardest as to ease of replacement if necessary ( don't have a million in the bank, lol ).So what say you folk....
I replaced the 40 year old galvanized tanks in our current boat this past year with plastic because maybe they can deal with the new fuels better....
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: aluminium Fuel tank questions
T-Merc 350 Mag MPI (300hp)
I have had many other older boats (one SeaRay 1971 a friend of mine still has it) and never had a tank problem. I currently have a 1990 Proline 17' center console with an aluminum tank that is almost always wet due to be mounted low and center, and it is solid.
this would lead me to believe either Carver specified thinner wall tanks for a couple years to cut costs or their supplier cut corners with thickness and or quality of the aluminum?
anothernewb
- Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212 - Location: Space Coast Florida
- Been thanked: 21 times
- drosteo
- Vessel Info: 1989 Carver Montego 2157 5.7 L Mercruiser Aplha One
- Has thanked: 3 times
My questions are
Does anyone know if what I've described regarding resistance of fuel coming out is normal?
Also is this brass elbow a one way valve?
Is it a metal stem or rubber hose inside the tank attached to this?
It is very hard to remove this elbow and I'd rather not if everything described above is normal. Air flow in to the fuel tank is clear. Was getting fine and stable readings on my Lowrance fuel flow sensor but now I'm getting readings that jump all over the place. Could be the sensor or could be the outlet on the fuel tank.
Thanks in advance
They are a safety device to prevent a broken hose from being able to siphon gas out of your tank and into your bilge.
Usually the "dip tube" is some kind of metal or hard plastic. That goes from the elbow at the top down near the bottom of the tank. They usually don't go all the way down though, so there's always an inch or so of fuel left that the tube can't reach
If the anti-siphon valve is working properly, it shouldn't take much to overcome it to extract fuel. Requiring any more vacuum than 2 inHg increases the chances of vapor lock so the valve should open before reaching that point. A dirty valve is the most common reason for valve problems.
