macerator power
- BRHEAUME
- Vessel Info: 1995 Carver 355
- Has thanked: 11 times
macerator power
I'm having an issue with power to my aft cabin head macerator and waste tank level display. I'm thinking they are both on the same circuit, as they both cut out at the same time. Additional to the breaker in the power control box, is there anywhere else to check? I don't recall Carver using fuses, after the breakers.
Thanks.
Re: macerator power
Re: macerator power
If it's the original install, you should have separate breakers for forward and aft heads, and forward and aft waste tank monitors, total of four breakers. I didn't think that when the high level cut off relay was installed, that it would also shut of your red "full" light, but it may.
