Aft deck plastic panels
Used boat parts, used Carver boat parts, trailers, dinghies, outboards, props...everything but the boats they were attached to. ALL ADS ARE FREE - USERS MUST HAVE AT LEAST 10 POSTS TO PLACE AN AD
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
Wayne162
"Change In Latitude"
Has thanked: 16 times
Been thanked: 32 times
Re: Aft deck plastic panels
Postby Wayne162 » June 5th, 2019, 7:44 pm
Hey Kend,
Mine were attached with what appeared to be 5200 or similar product. I think I used a solvent to soften it up then a razor, a knife blade and a flat tip screwdriver to get it out of the groove once separated. It was a pain in the A$@!
:usa:
KEND
Vessel Info: 1991 Carver 33' wide body aft cabin model 3330 twin 330hp Volvo's
Been thanked: 2 times
Postby KEND » June 5th, 2019, 8:19 pm
Thanks, what kind of solvent, I tried paint thinner and goo off, no luck, at least I know they will come apart.
Wayne162
Postby Wayne162 » June 5th, 2019, 8:47 pm
I think I used mineral spirits. You could also try alcohol to break down the silicone bond and to temper the aggravation!
:drunk:
KEND
Postby KEND » June 6th, 2019, 9:04 pm
Maybe this will help someone else, by suggestion of a friend I used a heat gun and heated up along the slot on the aluminum corner piece and put a screw driver just behind the edge at the top of the plastic and it came apart in a few minutes. Now I just need to get the plastic cut and drilled.
1992330aftcabin
Vessel Info: 1992 330 Carver aft cabin
Has thanked: 54 times
Postby 1992330aftcabin » April 8th, 2020, 10:50 am
Kend, I have a 92 330 Aft cabin I was wanting to replace the dodgers on who was your supplier for the panels. I see you’re from Grosse Ile, we keep our boat in Wyandotte. Hope to cross paths. Thanks Mike
Bentone23
454 xli TBI Crusaders
Has thanked: 57 times
Been thanked: 5 times
Postby Bentone23 » October 23rd, 2021, 6:22 pm
Wayne162 wrote:If you are looking to do it yourself if the parts are not available from Carver, try Mcmaster-Carr. I purchased a 4' x 8' sheet of UV protected acrylic panel that I cut for a snow plow blade insert. They are on line and supply bulk composite material in whatever size you specify. My sheet ran about $80.00. :usa:
I just looked on their site. $214 for a 4’x8’ sheet of 1/4”. No quote on delivery yet.
Bruce Bennett
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
Bentone23
Postby Bentone23 » October 23rd, 2021, 6:27 pm
KEND wrote:I also have two cracked panels for my 1991 33 aft, My problem is I cannot get the corner piece off the plexiglas panels on either side, so without separating the plexiglas I cannot use the corners. They seem to be locked on, maybe glued, not sure , all I know is no matter what, I have even tried to separate them using a razor knife to scrap inside the edges. No matter what I try no luck, any suggestions ?
Shatter the plastic out with a chisel.
Bruce Bennett
1996 355 Aft Cabin
Central California
Wayne162
Postby Wayne162 » October 23rd, 2021, 9:50 pm
I know I used mineral spirits and poured it down the channel of the corner and let it sit for bit. I did use a knife tip to break the bond once is became soft.
:usa:
Glassman
Postby Glassman » October 12th, 2024, 6:00 pm
I make the 1996 Carver after deck corner pieces that were aluminum from fiberglass !!! :-D
Return to “Boat Parts For Sale”
Users browsing this forum: Google [Bot] and 9 guests
