Hull number deciphering, what info does this give?
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
@jim: insert some pictures here, surely someone can tell you more about that particular model.
quote="hull numbers are missing from the boat. all i have is the hull # from the title i received when i got the boat, OHZ51149F073[/quote]
- Has thanked: 602 times
Re: Hull number deciphering, what info does this give?
Individuals building boats for their own use and not for the purposes of sale are what are referred to as “backyard boat builders.” They must obtain a 12 character Hull ID Number from their State boating agency. The Manufacturer Identification Code at the beginning of the HIN for a “home built” boat is an abbreviation for the State followed by a “Z” which indicates that it is a State identification.
Hard to say the actual reasons for that number being on the title.....if he could provide a picture it would perhaps be more obvious.
Here is a link to the site..https://www.boatsafe.com/hull-id-numbers/
It wouldn't hurt to look elsewhere in the boat for an OEM number. The stringers were a pretty common location. It may also be worth using a light in the typical locations where hull numbers are molded into the hull such as the starboard transom corner or starb aft corner of the hull side. That area of the hull may have been damaged in the past and a repair makes it seem like a number was never there. Shining a light at different angles may reveal remnants of a number if a repair was superficial. If the number was on a plaque affixed to the hull as they commonly are on Carvers and it was lost, you may be out of luck, that's why I'm not crazy about them. As long as you have the number recorded elsewhere though, you can have a replacement made. I've dealt with accidents that have destroyed molded numbers, in those cases I would have a plaque made as it's the easiest way to affix a number back on. The number is needed on the outside for several reasons, but they are prone to getting damaged, this is why a number inside the boat as well (stringers, electrical panel, etc.) is a good idea.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- jim jamison
- Vessel Info: According to title I Was given, it is a 1973 Carver 2275 Camper 22 ft it has a Merc cruser straight 6 165 hp. THE BOAT WAS GIVEN TO ME, BUT WAS TOLD IT WAS A 1984 24 FOOTER! problem is there is no hull number! I have the serial number 32275108 . I WAS ABLE THE FIND A PICTURE OF A 1978 Carver Camper 22 ft HAS THE SAME DASH......... BUT THE PORT WINDOWS IN THE CUDDY ARE DIFFERENT. THIS BOAT WAS STORED INSIDE MOST OF IT'S LIFE SUPER CLEAN AND RUNS GREAT NEED HELP MAKING SURE EXACTLY WHAT I HAVE! AND POSSIBLY GETTING A HULL #
hull numbers are missing from the boat. all i have is the hull # from the title i received when i got the boat, OHZ51149F073 - Location: OHIO
- Has thanked: 1 time
[/quote]Phrancus wrote:Source of the post Got the following message from Jim through a PM, I seem to remember that the hull number is built up of various segments that refer to certain location/year and perhaps model. The latter is what Jim is looking for as apparently there's a lot missing from the boat he obtained.
- jim jamison
- Cooler
Users browsing this forum: No registered users and 50 guests
