Carver 396 - How to remove aft cabin night stand
NewVenture
Vessel Info: 2000 Carver 396
Has thanked: 2 times
Postby NewVenture » July 28th, 2025, 6:24 pm
I want to get access to the area around and under the right side (near engines) night stand and wonder if anyone has pics or instructions on how to remove that night stand? I've removed the main salon a/c cabinet several times over the years and it just lifts off the wall mounted wooden cleat. Not sure how to go about removing the nightstands and don't want to just start yanking away. Also, getting a bit too old to be laying on the floor and looking around inside of it for fasteners, etc., so hoping it's similar to the salon lift-off cabinet.
Appreciate the help! Thanks!
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Re: Carver 396 - How to remove aft cabin night stand
Postby KyleR » July 29th, 2025, 12:31 am
Unfortunately they are not lift-offs like the air conditioning cover in the salon.
Fortunately they are just held in place by a few wood screws inside the cabinets.
Unfortunately you will definitely have to get on your hands and knees to find all the screws.
Fortunately once they are all out the cabinet will just lift right out of place.
Unfortunately they are bulky and awkward to move around.
Fortunately you will find some great access to some important equipment (galvanic isolator, shore power connections, shore water connection, port muffler connections, black water line connections....just to name the ones that come to mind. :-D
What specifically are you looking for? Maybe I can help.
Good luck!
Kyle
MV Verity
2002 Carver 396
Postby km1125 » July 29th, 2025, 9:07 am
Considering this....
KyleR wrote:Source of the post
... Fortunately you will find some great access to some important equipment (galvanic isolator, shore power connections, shore water connection, port muffler connections, black water line connections... ...
Once you get it out and while you have it out you might consider how you could use some slip hinges or slide brackets and/or
some "Marine Locker Hatch Stainless Steel Anti-Rattle Latch Boat Fastener Clamps" on the inside to re-fasten it down when you're done!
NewVenture
Postby NewVenture » July 29th, 2025, 1:04 pm
KyleR wrote:Source of the post Unfortunately they are not lift-offs like the air conditioning cover in the salon.
Good luck!
Kyle
Thanks for that info! I figured there was likely someone who has done this!
Right now, I'm simply looking at trying to get back there for cleaning, carpet shampooing, etc., but also looking at someday replacing the aft stateroom carpet. It all lifts up easily — except under the nightstand. Thus looking at the option of taking the nightstand out in order to remove that entire carpet, taking to carpet store to have a new piece cut.
Luckily in 11 years onboard, haven't had to access anything back there, but have thought about it when changing the shore water valve, etc.
Again, thanks for the info.
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Postby paulr » July 29th, 2025, 5:13 pm
When I bought 2001396 the aft state room night table on the right side of the bed when facing the bed, the carpet only went half way the night table. I never knew it until I cleaned under there.
NewVenture
Postby NewVenture » July 29th, 2025, 6:38 pm
km1125 wrote:Source of the post Considering this....
Knowing now what to look for, you are on the right track. I now see that a PO had done pretty much that — replaced the multiple screws with only 2 obvious key screws, so looks like the job would be fairly easy, even for an old guy! Just a matter of handling the thing to get it out of the way. Now just have to work up the energy to add it to my never-ending ToDo list! :approve:
