Carver Mariner propeller shaft diamater
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » September 19th, 2016, 9:00 am
Carver Mariner propeller shaft diamater? I'm looking to pick up a propeller puller incase I need to remove my props. I'm not sure the the diamater of the prop shaft. Any one know what it is?
Re: Carver Mariner propeller shaft diamater
Postby bud37 » September 19th, 2016, 6:55 pm
Go to the Carver Yachts.com website and look under the owners drop down,there you will find parts manuals etc.....pick thru and choose your model and year....its all there....lots of info...hope this helps... :beergood:
amanphoto
Postby amanphoto » September 20th, 2016, 7:31 am
thanks for the help. I looked it up and It's 1.5"
What propeller puller do you use? What the best?
Been thanked: 248 times
Postby mjk1040 » September 20th, 2016, 3:29 pm
The one that looks like a C-Clamp is the best, and I think one size fits them all. You are going to need a torch with map gas to apply some heat or they will never come off. Did you finally buy a 350 Mariner or are you still fishing? Mike
amanphoto
Postby amanphoto » September 20th, 2016, 5:55 pm
I'm still fishing. I've got one in my sights though. Making the move next spring.
I'm a diver and have removed damaged props and installed fixed ones underwater for people. I've had to tap them off. A puller would be nice.
Postby mjk1040 » September 20th, 2016, 7:57 pm
You'd do better to try and buy one now, those looking to get out of boating are dealing in the fall more so than in the spring.
Mike
Postby Viper » September 20th, 2016, 9:43 pm
Prop pullers are limited to shaft size so get one that will accomodate the range you'll be dealing with. Any shaft above that range will require a larger puller.
