Carver 1/8" or 3/16" SS cable swage tool
dsolo
Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll
Has thanked: 68 times
Been thanked: 25 times
Postby dsolo » February 21st, 2017, 9:07 am
I will be finishing up replacing all the SS/PVC life lines on the 405 Carver. Bought the swage toggle terminals, swage studs and PVC SS cable from BOSUN Supply.
I bought the swage tool and can make it available to anyone wanting to crimp 1/8" or 3/16" cable. Not sure if I will use it again? Only ask it get sent back after use. Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Re: Carver 1/8" or 3/16" SS cable swage tool
Postby Viper » February 21st, 2017, 11:49 am
Wow, that's a really generous Dan. Thanks for the offer. Will keep it in mind. :down:
Postby g36 » February 21st, 2017, 1:17 pm
I may take you up on that. I've been wanting to replace these parts with new. Do you mind posting what you used?
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » February 21st, 2017, 3:59 pm
Below are listed the BOSUN Supply item codes:
S0708-0307, SS wire PVC 316, 7x7, 1/8"x1/4". 37'
S0737-H003, SS hand Swage toggle terminals 1/8" 8ea
S0732-H0703, SS hand Swage Stud 1/8" wire LH. 8ea
The left handed treaded stud threads into your existing spring clasps. Saves a lot money if you can reuse them.
Cable is $.83 per foot.
Toggle terminals are $9.44 EA
Studs are 6.75 EA
The swage tool is held in vice and has two grade 8 bolts between two jaws. Insert terminal into jaws, cable into terminal, ratchet bolts to close jaws and form crimp on terminal. Rotate terminal 180 degrees and I crimped each terminal 4 times alternating each crimp 180 degrees. Better looking than the factory crimps.
Your more than welcome to the tool.
Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » February 22nd, 2017, 4:50 pm
g36, I also have the SS cutting tool for the cable. You will need it also if you decide to go with the project. No problem sending both.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby g36 » February 23rd, 2017, 9:09 am
thank you i will be in touch, i need to definetly this to do mine i will move this project up on my list. i bet the new lines sure look good
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » February 23rd, 2017, 9:29 am
Previous lines were brown and cracked from years of sun and handling. Need to treat with a good vinyl protection. Looking forward to getting them installed. Also replaced windshield canvas, Maxwell foot switch covers, and swim ladder hand grip. Canvas overall has a couple good years left.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
