1984 3207 Ignition Conversion
Been thanked: 248 times
Re: 1984 3207 Ignition Conversion
Postby mjk1040 » March 15th, 2017, 5:14 pm
Personally, I would replace both distributers with new electronic Mallory's and new coils and be done with it. Mike
paboater76
Vessel Info: 84 3207 Aft Cabin
Has thanked: 14 times
Been thanked: 5 times
Postby paboater76 » March 21st, 2017, 2:36 pm
Thanks everyone one. I went the conversion route. Installed 2 of the Sierra International 18-5296-2 Ignitor Electronic Ignition Conversion Kits.
We also replaced the springs with new OEM mallory springs. Cleaned everything up and well see in a few weeks if that did the trick. I will look at full replacement if this does not work.
The springs we extremely rusted over and looked pretty bad. The weights just needed a light brushing and they looked like new. Again, well see. Once the engines are fired up for the first time this year, mechanic will come back and adjust carbs (Both carbs just fully rebuilt) and time engines.
Thanks all!
Postby Viper » March 21st, 2017, 6:49 pm
I hope the tech is checking the timing.
Been thanked: 491 times
Postby waybomb » March 21st, 2017, 7:04 pm
When I re-awoke my dormant-for-ten-years beast, I used the points to pre-time the engine. Rotated engine in direction of rotation and stopped at 8bdtc on compression stroke (valve covers were off when I did this). Hooked up an ohm meter to both sides of the points. Turned the distributor to get the rotor pointing at #1 plug then tweaked it so the points were just opening up.
Poured gas into the carb vents.
Bingo!
Started and running with one or two revolutions. I did have to adjust the timing a couple degrees, because I had to adjust dwell, but I was close.
Later changed to Pertronix.
paboater76
Postby paboater76 » March 24th, 2017, 1:18 pm
Viper wrote:Source of the post I hope the tech is checking the timing.
Yes, he will when we run the for the first time this season, hopefully in a couple weeks!
paboater76
Postby paboater76 » April 14th, 2017, 8:25 am
Just a final update on the post, we fired up the engines for the first time this year and first time with new upgraded ignitions , new springs and general cleanup of the distro.
Mech set carbs and base and TA timing and both engines ran and sounded great! he primed the system, hit the button and boom they came to life and didn't miss a beat. I couldn't be happier.
Thanks gain for everyone's input and replies. Happy boating season!
Postby waybomb » April 14th, 2017, 12:55 pm
Awesome.
Now, go boating!
Wzdr02
Vessel Info: 1988 Carver 4207 w/CAT 3208TA
Has thanked: 2 times
Postby Wzdr02 » April 18th, 2017, 3:14 pm
Pertronics
Users browsing this forum: No registered users and 77 guests
