Marine Air A/C blows breaker instantly
Been thanked: 470 times
Re: Marine Air A/C blows breaker instantly
Postby RGrew176 » June 19th, 2019, 1:58 am
Thanks for posting the solution to your problem. Someone else down the line with the same issue will have a solution posted.
Postby tomschauer » June 19th, 2019, 1:18 pm
Sounds like you have some A/C experience. If the compressor failed electrically (shorted windings) as you mention. Make sure you do an acid test on the oil before installing a new compressor. If there is high acid content the new compressor wont last very long.
