Starboard Engine
Topic author
bevenfl
Vessel Info: 19' 1889 Carver Mariner
Starboard Engine
Postby bevenfl » September 30th, 2014, 9:49 pm
When I turn on the batteries the starboard engine starts to turn over with noise coming from the battery switch. Is this a problem with the battery switch or could it be related to the ignition switch?
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Starboard Engine
Postby Lyndon670 » September 30th, 2014, 10:35 pm
Are you saying that as soon as you rotate the battery switch from the "off" position to the "on" position that the starboard motor tries to start? If that's the case, sounds like the starboard starter solenoid is stuck in the "on" position.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Topic author
bevenfl
Postby bevenfl » October 1st, 2014, 7:31 am
Not immediately. When I first noticed it was when I was sitting in the cabin and used my cell phone. Sometimes it takes 10+ minutes to happen. That's what confuses me. With the batteries off, I went to the bridge and operated the switch several times. Then it took some time but eventually did it again.
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » October 1st, 2014, 10:53 am
I would be looking at the neural safety switch, and the starter solenoid. Start with the neutral saftey switch - it's an interrupter circuit on your ignition switch. Not sure about yours, but check for wiring coming from your shifter. Either way it's not expensive, just a pain in the ass.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Topic author
bevenfl
Postby bevenfl » October 3rd, 2014, 8:38 am
Thanks, I'll try those. These are 501 gas engines.
Users browsing this forum: No registered users and 45 guests
