Just bought a Carver have a couple issues/questions
Re: Just bought a Carver have a couple issues/questions
Postby km1125 » August 8th, 2019, 11:08 pm
Also look for an in-line fuse in the power wire right by the pump. My 83 had one there, as well as a breaker on the panel.
On the fuel gauge... the switch is a temporary switch. You have to hold it to port or starboard to check the fuel level, and it gets power from ONE of the engine ignition switches. On mine it's the port engine.
Postby km1125 » August 8th, 2019, 11:13 pm
Also check for an in-line fuse in the power wire right by the pump. Mine had one as well as the breaker on the panel.
On the fuel gauge. The switch is a momentary-contact switch, so you have to hold it to port or starboard to get a reading on the gauge, and it's powered by ONE of the ignition switches. Mine is powered by the Port engine ignition switch.
Postby tomschauer » August 9th, 2019, 9:12 am
if its a 1988 27, it most likely only has a single fuel tank and a fuse panel, no breakers.
Been thanked: 470 times
Postby RGrew176 » August 9th, 2019, 4:46 pm
Welcome Aboard. Good luck with your Santego. Hopefully your issues are few and far between.
Users browsing this forum: No registered users and 37 guests
