Question about water coming out exhaust.
VicB
Vessel Info: 1988 Carver 3807
Has thanked: 41 times
Been thanked: 11 times
Postby VicB » June 11th, 2020, 10:45 pm
I have a 88’ 3807. For lack of a better term, there seems to be an exhaust vault glassed into each side of the boat. There are holes on each side that divert each engines exhaust under water. There is also a large stainless square tip on each side of the boat that exhausts water from engines, AC water pump and generator exhaust. On the starboard side I noticed water coming out of the tip like it was supposed to AND water coming out the bottom, between the boat and tip. Maybe it does that on both sides? I had already shut the port engine down when I noticed this and it was getting dark. Has anyone taken these off? Maybe just a sealant issue?
Has thanked: 474 times
Re: Question about water coming out exhaust.
Postby Viper » June 12th, 2020, 6:46 am
Interesting Vic, mine has the holes on the side and bottom but not the square tip you're talking about. Can you post a photo?
Are you saying that you didn't notice any water coming out of the exhaust ports/holes on the port side? It can be difficult to see water coming from the bottom holes at an idle, it's not underwater exhaust but they're very close to the water line.
VicB
Postby VicB » June 12th, 2020, 7:57 am
Viper, I was hoping you’d see this post. I remembered you and I have the same boat and you’ve been a tremendous help to me in the past. First, I want to thank you for sharing all your experience. You’ve been on of the best resources for getting to know our Carvers and their systems, not just for me, but a lot of folks on this forum. Second, you are right about the holes in the aft for exhaust. Mine are an inch or two above the waterline, which does make it nice to check for water output before we untie from the dock. My side exhaust tips may have been an add on somewhere along the way. We are taking my daughter and a bunch of her friends out this evening, so I’ll snap some pics. Thanks again!
VicB
Postby VicB » June 22nd, 2020, 2:40 pm
Here is a picture of the exhaust. I can see that there is at least one screw missing. I'm hoping it is maybe some missing sealant and a couple of screws.
Been thanked: 248 times
Postby mjk1040 » June 22nd, 2020, 6:11 pm
Those sure look like add-on's IMO. And I don't see any sealant at all!
Postby Viper » June 23rd, 2020, 6:57 am
Interesting, never seen those before. I guess the big question is; why? Would be interesting to find out if it was factory or a previous owner but that's the first time I've seen that design on any brand.
Postby bud37 » June 23rd, 2020, 8:26 am
Looks like a version of a clam shell that someone has made up to me. Nice job on the finish.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » June 23rd, 2020, 11:21 am
Definitely not original. Must be PO installed to stop muskrats or critters from entering exhaust. Or, he wanted noise level lower diverting DB's to the aft. Solid glass there, so no coring rot. 8-) er
Cooler By The Lake
Been thanked: 491 times
Postby waybomb » June 23rd, 2020, 12:41 pm
That is what is on my 87 Mariner. A buddy also has an 87 Mariner with the same thing.
