changing the carroborators
captainjohn
Topic author - Scurvy Dog
- Vessel Info: 1990 "406 Aft Cabin"
We are new to the forum and are very excited about our new boat.
- JediJD
- Vessel Info: 2007 Carver 42SS
Woodstock, GA - Has thanked: 1 time
Re: changing the carroborators
Sooooo...the process usually goes something like this...first, check air filters. Make absolutely sure they are allowing the most/cleanest air possible with the fewest obstructions. Then, with air absolutely perfect, look at the plugs, plug wires, cap/rotor...anything associated with the primary or secondary ignition system and make sure all of that is spot on. Then, with the air right, and the ignition right, check the timing and advance mechanisms (that's the whole timing light thingy). The idea here is that the piston is coming up in the cylinder and compressing this air fuel mixture and you want most of the explosion when the compression is precisely the highest (think about the difference between gunpower exploding loose on a driveway versus being compressed in a firecracker case) and it would make sense that if you try and explode the mixture too early...or too late...you won't get the maximum benefit. Making this even more interesting...the mixture doesn't all explode at once. The spark actually lights a small spot which spreads across the mixture (its called flame front propagation and that is part of the theory behind multiple node spark plugs) so not only is the timing important for full compression, but also takes into account the amount of time it takes for the mixture to burn. Meaning...get the timing right. There are actually two parts of timing...base timing (where the engine is at idle) and something called "advance". Advance has to do with the idea that, as your engine rotates faster, the piston spends even less time in the compression stroke and thus you have to start that spark even earlier...sort of like leading a receiver with a football. OK...now that you have air, ignition, and timing its a good time to double check fuel filters. Clogged fuel filters can affect the volume of fuel available to a carburetor...especially at wide open throttle.
Now, with air perfect, ignition perfect, timing and advance perfect and plenty of clear fuel, delivered in sufficient volumes, you can take a look at the carb. You could just change it, but most of the time, the carb is matched to the intake and the exhaust (makes sense that if you want the perfect mixture, you want to know exactly the volumetric efficiency of the intake, but believe it or not, getting the spent exhaust out of the engine is equally important (think headers on an old Pontiac). Won't do you a bit of good to burn more air better if it doesn't have anywhere to go. Assuming you aren't changing it, and insist on fooling with it, most carbs have adjustment screws at the base and a pretty standard process is to rotate the adjustment screw out a full turn or two, then bring it back in, a quarter turn at a time, waiting for RPM's to drop about 50 or so, then back it back out an eighth. However, I hope it makes sense to you that if you start with the last part, without doing the earlier stuff, its sort of like washing your hands before you clean a toilet...nothing wrong with it, but it doesn't accomplish much.
Lakes Allatoona and Lanier, GA
'07 Carver 42SS "A Little More Nauti"
(tender is a '15 VX Cruiser "Littler Nauti"
'03 Sea Ray 380DA "A Little Nauti" (sold and missed)
captainjohn
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
If that doesn't work, you will get amazing fuel economy staying at the dock !!
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
captainjohn
- Been thanked: 490 times
Users browsing this forum: No registered users and 62 guests
