Hydraulic Steering
- Bill L
- Vessel Info: 1993 Carver 300 Aft Cabin
- Has thanked: 1 time
Hydraulic Steering
- Been thanked: 654 times
Re: Hydraulic Steering
- Beufort
- Vessel Info: 86’ montego 26.
- Has thanked: 4 times
- Been thanked: 5 times
Mine is located right at the steering column which actually looks like a steering wheel tension knob,
Then there is the fill bottle which is located near the rudders which looks like a typical automotive brake fluid bottle.
It is not as easy as fill her up, there is a procedure for doing this correctly in order to bleed the air out. Find out what brand they put in yours and follow their bleeding recommendations.
Found this which is rather helpful in pointing you in the right direction however this is the lazy mans way.
Here is the correct full procedure. https://www.boats.net/blog/how-to-purge ... c-steering
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Cooler
- Has thanked: 474 times
If you have a pressurized system with a reservoir/pressure tank, make sure you release the pressure first, and the tank is where you should be filling.
- Bill L
