444 aft sliding door trim
extraextra
Vessel Info: 1998 405, 2005 444
Postby extraextra » August 11th, 2020, 2:50 pm
On the outside of the rear sliding door on the 444, there is a rubberized "white filler molding" around the frame of the door on the aft cockpit. It has gotten sticky & has discolored. Does anyone know where to get this?
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: 444 aft sliding door trim
Postby Tireless » August 16th, 2020, 8:28 pm
I called Carver looking for the black windshield trim on my 44 and they turned me onto the company that manufactured the windshield. The still have the rubber trim and I will order it. Maybe they made the sliders as well. The company was called Aluminum 2000. I sent an email and received an email back from their service department.
Stephanie D. Allen
Bomar Customer Service Rep.
603-826-5791
She sent me a sheet back with all the rubber trim pieces that they have.
Greg
extraextra
Postby extraextra » August 18th, 2020, 11:53 am
Thanks for the info, I will give it a try.
Postby km1125 » August 18th, 2020, 1:25 pm
While you're looking for a replacement, try wiping the old one with a white rag soaked in acetone. It's probably PVC and the acetone could make it look like new and would take the 'sticky' off of it (once the acetone evaporates). Just takes one good wet rag and one good swipe.
Brazil
Hugo
Has thanked: 2 times
Been thanked: 23 times
Postby Hugo » August 18th, 2020, 3:42 pm
Collinite fiberglass cleaner works for me on the that gasket.
Trend marine makes the rear door. I have purchased them in the past from lizzie@trendmarine.com, part number RP094B "White Flexible Clip In". If this contact doesn't work contact trend marine directly. This is not aluminum 2000, that was the windshield and they are no longer made.
Brazil
Hugo
Postby Hugo » August 18th, 2020, 3:50 pm
Edited double post...
extraextra
Postby extraextra » August 24th, 2020, 12:04 pm
Thanks Hugo, I will contact them. Hope all is well!
