Fuel tank leaking
- Has thanked: 474 times
Re: Fuel tank leaking
- Has thanked: 603 times
bud37 wrote:Source of the post My best advice for anyone confronted with this that has no working safety experience with gasoline tanks .....leave the removal to the pros
Guys I stand by my advice, it is all in that first line and said that for a reason, if you have to ask how then working with gas tanks/fuel leaks etc in confined spaces is not something you should be doing period. I care about peoples safety not their inconvenience or wallets. Remember this forum is read by boaters across the world.
Sure if you have experience and have had multiple boats over the years then all are free to do anything, but for new boaters that may have just started ( this year especially ) with zero experience trying to explain how to do that safely is impossible and could lead to a disaster.
I hear ya and agree that it is hard to find good help but this is way more than changing out a water pump etc.
Stay safe.
- Flippenout
- Vessel Info: 1978 Carver 25.5 ft Santa Cruz cabin cruiser. Duel helm.
my friend was welding his problem on his gas tank and he used his water hose filled it with water drained it and let it set for couple of weeks. After two weeks of airing it out he put a mig welder on it to plug the holes and it blew up from a square gas tank to a round marshmellow, he's lucky son of a bitch, I've ever meet. Corison on the out side it's for sure on the inside,. Gas makes pockets in the aluminum, when mig weld penetrated aluminum, since it's a hole he was doing.boom. I have the same problem as you, filled gas tank with water, plugged the holes up for intake and Return lines. So it's full of water after two months cut bottom off bought a new peice of aluminum. Weld a new peice on. It cost 146 dollars for 4 by 4 3/8 thick and welder took 2 hours charged me 300 bucks. It's fixed and I'm out 450 and I'm alive to tell about it
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
Happened to me in my 25' Santa cruz. The tank itself is supported off the bottom so corrosion leakage is unlikely (but not impossible).
Check the sender gasket.
Phil Little.
