Battery charger settings
- Jay Fusaro
- Vessel Info: 1998 445 Aft Cabin
- Has thanked: 75 times
- Been thanked: 3 times
Thanks!
Jay
AquaVilla
Re: Battery charger settings
- Jay Fusaro
AquaVilla
- Has thanked: 603 times
Jay Fusaro wrote:Source of the post Thank you I agree - they are lead-acid. I'm not sure why the prior owner chose to not use the float option on the 3 Stage.
Does it happen to give the charge time lengths for the different settings in the manual ?.......it may simply be, he didn't realize it or never left the boat plugged in so float wasn't an issue.....just a guess on my part though.
Not really a good place to put it. Then again they have built cars where you need to lower the engine to change plugs.- Jay Fusaro
bud37 wrote:Source of the postJay Fusaro wrote:Source of the post Thank you I agree - they are lead-acid. I'm not sure why the prior owner chose to not use the float option on the 3 Stage.
I was just looking in the manual and it doesn't give the charge lengths - it simply describes what bulk and absorption are and that once the proper charge level is reached it will shut off.
AquaVilla
- Jay Fusaro
Midnightsun wrote:Source of the post Agreed, 3 stage is what you want. Weird things happen though. When I swapped out my factory Charles charger found out it was set to AGM however they are lead acid. You needed to unscrew the charger from the wall as the settings switch was located in the rear of the unit.Not really a good place to put it. Then again they have built cars where you need to lower the engine to change plugs.
No doubt! I just wasn't sure if I was missing something. Maybe some people think leaving it on float will cook the batteries??
AquaVilla
Users browsing this forum: Beachlovers and 25 guests
