Port and Stbd Navigation Light Replacements
gmac98004
Vessel Info: Proud new owner - '98 355 Aft Cabin "Invictus"
6BT5.9M 210hp
Formerly - 1986 - 30' Newport MKIII
Has thanked: 451 times
Been thanked: 12 times
Postby gmac98004 » April 15th, 2023, 9:09 pm
Hello Everyone,
The housing on my Stbd navigation light has crumbled to pieces after 25 years of weather, rain, snow and spray abuse.
After an embarrassing amount of time searching for the white Aqua Signal Series 25 replacement part, I have given up.
Does anyone have a recommended substitute that can mate up with our aluminum "L" shaped mounting brackets?
Thanks for all of your support!
Take Care, Greg
1998 355 Aft
Invicuts
Re: Port and Stbd Navigation Light Replacements
Postby Viper » April 16th, 2023, 8:14 am
Did you go on Aqua Signal's site... https://www.aquasignal.com.au/shop/port-starboard-classic/series-25-classic/?
They show them there so they should still be available.
Starboard part number is 3511195000
Port part number is 3510295000
gmac98004
6BT5.9M 210hp
Postby gmac98004 » April 16th, 2023, 12:07 pm
Thanks Viper.
Yes! Only black is available.
Would love a fully LED option in white that still can mount to our "L" shaped brackets!
Thanks Again, Greg
Postby Viper » April 17th, 2023, 9:03 am
Postby g36 » April 17th, 2023, 9:22 am
If you find the fixture you like just could purchase a proper led bulb for it rather than trying to find a led fixture
Postby g36 » April 17th, 2023, 9:59 am
I found you a white port one but you need stbd I see
Drspikes355
Vessel Info: 1996 Carver 355 aft cabin Crusader 454’s
Has thanked: 135 times
Been thanked: 3 times
Postby Drspikes355 » May 2nd, 2023, 12:18 pm
I just replaced mine this weekend and the black really isn’t noticeable. I did have to enlarge the two mounting holes in the new plastic but perfect fit.
I also put a new folding anchor light that is LED but don’t feel the need for LED running lights.
All other cabin lights are LED for low draw while at anchor.
Users browsing this forum: Beachlovers and 25 guests
