Small Covered Port on Bridge with two terminals?
Been thanked: 1114 times
Re: Small Covered Port on Bridge with two terminals?
Postby km1125 » June 8th, 2023, 7:49 pm
You could probably confirm it just by putting a voltmeter on those two terminals inside and then toggling the anchor light switch and see the results on the meter.
Postby bud37 » June 8th, 2023, 8:37 pm
Have you looked at some boats for sale just like yours or google pics......sure does look like where you would expect the anchor/running light post to be.
theorifice
Vessel Info: 1987 Carver Santego 30
Has thanked: 16 times
Been thanked: 4 times
Postby theorifice » June 20th, 2023, 1:08 pm
thanks all. Still haven't been able to put a meter on it but I found from another pic that it is a Perko Plug-In Type Base.
https://www.perko.com/catalog/navigatio ... type_base/
Fun times on the 1988 Carver Santego 30
Hold'n On II
Vessel Info: New to us 1996 370 Voyager
Been thanked: 11 times
Postby Hold'n On II » June 21st, 2023, 11:04 pm
Anchor lights are typically installed at the highest point on the boat so as to have 360 viewable light.
If on the bow, it's probably a socket for a remote search light. Our 370 has a removable remote search light on the Fly Hood with a similar looking socket.
Hoplite808
Vessel Info: 1988 Carver 3227 Convertible
Been thanked: 8 times
Postby Hoplite808 » June 22nd, 2023, 2:25 am
It is definitely the corroded remnants of an anchor light plug.
https://www.westmarine.com/perko-plug-i ... 68385.html
Hoplite808
Postby Hoplite808 » June 22nd, 2023, 2:27 am
theorifice wrote:Source of the post What is this port for?
This is definitely the corroded remnants of an anchor light plug.
