1999 Carver 356 Aft Cabin Steering System
Todd_G71
Vessel Info: 1999 Carver 356 Aft Cabin with twin Cummins B4.5 series diesel engines and Garmin electronics (Auto pilot, chart plotters)
Has thanked: 4 times
Postby Todd_G71 » March 7th, 2025, 2:23 pm
I am trying to determine which type of steering system the boat has. Does anyone have the specs for the 1999 356 Aft Cabin for Steering? Is it hydraulic or mechanical? Thanks.
Re: 1999 Carver 356 Aft Cabin Steering System
Postby km1125 » March 7th, 2025, 3:03 pm
I don't know that specific model, but I'd bet 99% it's hydraulic.
Todd_G71
Postby Todd_G71 » March 7th, 2025, 4:16 pm
:pirate: awesome. Thank you sir!
Postby Viper » March 7th, 2025, 4:56 pm
Ya hydraulic for sure unless a previous owner changed something, either taking a step back to mechanical or upgrading to a fly-by-wire system. Your helm (part the steering wheel is mounted to) is the pump, and there is a steering cylinder aft at the transom that is connected to the rudders.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » March 8th, 2025, 11:36 am
It may be a Hynautic system. Look around in the engine room for a reservoir box, and monitor hydraulic fluid level there. If it gets too low, you will blow the seals in the steering pump. If there is a fill cap on the pump ( steering wheel ) location, then it is a SeaStar. Easier to keep full, and monitor. If you need to top off, make sure you use hydraulic steering fluid. Not the same fluid as trim tab/power steering fluid. The fluid containers are labeled in a really confusing way. Good luck. 8-) er
Cooler By The Lake
Postby g36 » March 9th, 2025, 10:38 am
Seastar hydraulic
