Using a thru-hull transducer on a 3807
VicB
Vessel Info: 1988 Carver 3807
Has thanked: 41 times
Been thanked: 11 times
Postby VicB » June 27th, 2025, 9:53 am
I just hauled out our 3807, mostly due to a leaking, original (1988) speedometer mechanism. It fit thru a 2-1/4” hole in the hull. Hasn’t worked in years. My thoughts were putting an updated transducer in there for more modern electronics might be cheaper than labor to re-fiberglass the hole and open me up to upgrade the electronics. Turns out to be true. Installer just enlarges existing hole by 5/8” and pops it in. Here’s the rub. He’s a bit gun shy. He says if I hit something it could shift it and leak. It’s flush with the bottom of the hull and sealed under the flange and threads through the hull with 3M 5200. I doubt you could move it if you try and if it does move, then the boat hit something that probably totaled it anyway. Don’t most larger inboard boats use thru hulls transducers? Doesn’t make sense to me, but I am old enough to know there’s always opportunity learn something new. I asked him to install it anyway and if that happens then it’s on me. I may learn the hard way. Thoughts?
Re: Using a thru-hull transducer on a 3807
Postby bud37 » June 27th, 2025, 10:22 am
Well you have a keel hanging down and props, supports etc all below the hull that would pretty much hit first I think.
Did he say if he thought your installation was somehow different from others he has done ? Looks to be quite the unit....
Postby Viper » June 27th, 2025, 12:35 pm
Nothing wrong with installing that unit as long as it's done right, it's the preferred type of installation IMO, don't know that I would use 5200 but it works.
Been thanked: 490 times
Postby waybomb » June 27th, 2025, 3:28 pm
All of my boats have had through hulls.
Never a problem
Users browsing this forum: Google Adsense [Bot] and 50 guests
