Bilges work on floats but not from helm switch
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
- Been thanked: 654 times
Re: Bilges work on floats but not from helm switch
- Merkinbrumsky
- Has thanked: 602 times
Merkinbrumsky wrote:Source of the post I haven’t touched the wiring. Who knows what was done before. I’m sure the bilge pumps aren’t OEM though as the boat is an 85 vintage 28 voyager. I will bring the multi meter with me next time and do some testing. I was wondering if maybe I was missing something obvious before I start pulling panels off again. Thanks for the reply.
Do the switches/breakers on the main 12vdc panel there still do anything? Just forward and aft, correct ? Likely over the years things have been changed, could even be the replaced pumps. Yup I'm guessing your in for a multimeter weekend. Good luck man...
- Merkinbrumsky
The switches still work, and yes just fwd and aft. Got up to the boat Sunday afternoon and dug in right away. After closer inspection it turns out a PO had stuffed the wire coming from the switch panels back into a wire chase. The connection to the power on the float switch had been made with electrical tape,
perfect for a bilge pump. I’m guessing the the wire from the switch panel came loose from the electrical tape connection and since the pump still worked on the float, somebody figured it was a not needed mystery wire and just stuffed it back up the pipe. Anyway, some quick heat shrink connections and it’s all back up and running as it should. Thanks to all those who replied. Nice to have a pretty easy win for once. Actually got to enjoy some time on the boat.- Kruggy88
- Vessel Info: 1991 carver 638 santego
