Kohler generator overheat after coolant replacement.
Tomion
Topic author - Deck Hand
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
Midnight Sun
- Vessel Info: 2007 Carver 41 CMY D6 370's
- Been thanked: 3 times
Re: Kohler generator overheat after coolant replacement.
- mjk1040
- Been thanked: 248 times
Sounds simple, or silly, but it works.
If you're refilling the system, put only enough coolant in till it gets to just above the bottom of the coolant tank. Take a vacuum (preferably a wet/dry one) and quickly hold the tube to the opening in the tank. It just takes a couple quick 'burps'. Check the coolant level. If it went down a bunch, add some and do it again. When it stops going down after you 'burp' it, then top to the correct level, put the cap on, then run the engine.
The vacuum also works great if you have work to do on the system and you want to drain all the coolant. Vacuum out the coolant reservoir, then take one of the top hoses off and vacuum the remaining coolant though that hose.
