Hurth 630 Transmission
- staticman4414
- Vessel Info: 1995 Carver Santego 310
Crusader 5.7L V-Drive - Location: Newburgh, IN
- Has thanked: 2 times
- Contact:
Thanks,
Joe
1995 Carver Santego 310 - Cruisader 350 V-Drive
Newburgh, IN
- Has thanked: 603 times
Re: Hurth 630 Transmission
- staticman4414
- Contact:
Joe
Newburgh, IN
- Bandit
- Vessel Info: ‘99 Carver 404
- Been thanked: 4 times
Depending when the clunk occurs you may find it is gear backlash which can occur if your engine idle is too low. Does it go away when you start picking up rom? If so check your engine manufacturers idle rpm preferably in gear if they show it.
You should be able to remove the tranny in the water but take precautions the shaft can’t slide too far depending on the seal configuration. You need to also ensure you have room to clear the shaft when removing the tranny.
While out check your drive damper bolted to the flywheel as it could have wear and tear of the springs or rubber blocks depending on what you have.
Regardless if you do it in or out of the water the final shaft alignment should be done in the water after the boat has settled.
Just my humble opinions not professional advise, good luck
