1999 MIE 7.4 MPI ECM Parameter's
- waterbug
- Vessel Info: Carver 350 Mariner
Searay 280 Weekender
Bayliner Trophy 2460 HT(sadly sold)
Sprint 260 - Location: Cumming, GA
- Has thanked: 3 times
- Been thanked: 2 times
Re: 1999 MIE 7.4 MPI ECM Parameter's
I checked the position of the throttle plate vs. throttle position at helm. Both are equal however there is a noticeable difference under way. Several degrees difference. I will check TPS with scanner as soon as I can.
I disconnected the "add-on" pumps and the original pumps were able to produce 40lbs steady at key on. Reconnected the "add-on" pumps and both maintain 40lbs. Will test underway as soon as I can.
As for the solenoid, STBD has a wire corroded completely off. So it has to be stuck in the "open" position because that engine actually runs better than the one with the "newer" solenoid.
I will do more testing and post as soon as I can. Stay safe out there and as always, thanks for all your input!
- waterbug
- Has thanked: 603 times
- Oldie
- Vessel Info: 1977 28' Santa Cruz
Single screw v drive - Has thanked: 2 times
The advantage you have is that you have 2 motors, one working, and one quirky..... it's "parts swap" time, to narrow it down. From your description, since it's not throwing codes and you're not going into limp mode, your MEFI is just picking a code based on the sensor inputs. As a guess, I would suspect your TPS. The carbon track could be faulty and sending the wrong Voltage to the ECM, and it thinks you have just throttled back, so picks an appropriate setting from the chart?
If it's a simple task, I would swap them out. I wouldn't try a Volt/Ohm meter in a static test, but rather a real world scenario. Continue swapping out easily accessible sensors, and see if your starboard motor now adopts the problem.
You mentioned that you checked the spark plugs and they seemed normal. Does this mean the were a nice tan colour, and not white or black? If they compare favorably (colour wise) to the good motor, this would indicate a healthy motor and MEFI, but it's just getting the wrong inputs. If they are white (lean) I would get professional help, to avoid destroying an engine.
Cheers.
