Distributors for Crusader 454XL?
Tarpley3
Vessel Info: Name: Moondancer
1995 370 Voyager
twin gas 454XL series - Crusader
Postby Tarpley3 » May 30th, 2020, 5:40 pm
I've got a 1995 370 Voyager with twin 454XL. The starboard HEI Ignition Module went bad and was replaced. The Cap and rotor were also worn, I had the spare parts so I replaced them as well. The distributor looks very old with signs of corrosion. I'd like to replace the distributors in both engines. Manual says Port is LH and Starboard is RH rotation. I've got Borg Warner transmissions. All I can find on-line is LH distributors (Sierra 18-5484-1 and similar). Will LH work in both engines?? Don't I need a distributor with a reverse gear for the STBD (RH) engine?
Re: Distributors for Crusader 454XL?
Postby bud37 » May 30th, 2020, 7:53 pm
I believe they drive the cam in the reverse engine with a gear....therefore the cam rotation is the same as the other engine which is chain driven........If you want, just pop the cap and watch the rotor turn as you hit the starter, or look at the firing order....should be the same distributor rotation for both, maybe that is why you can only find one part number.
At least that is the way it was. Really though maybe just a good cleaning and some new bits in there.
Tarpley3
1995 370 Voyager
Postby Tarpley3 » May 30th, 2020, 9:30 pm
According to the manual the firing order is different for each engine. But I'll check the rotor direction.
Postby km1125 » June 1st, 2020, 3:44 pm
Knowing the firing order you can also trace the spark plug wires back to the cap to determine which way to distributor rotates.
Postby Viper » June 1st, 2020, 9:48 pm
Usually the distributors on standard and counter rotators turn in the same direction. Firing orders are different though. The drive and driven gears are cut in the opposite directions for standard and counter rotators. In the past, distributor manufacturers either made a "counter rotating" distributor or sold the counter rotating gear separately to replace the standard one. The manufacturer should be able to help you out.
Tarpley3
1995 370 Voyager
Postby Tarpley3 » June 1st, 2020, 10:49 pm
Thanks. I'll let you know how it turns out.
