Trans lights always on
- Promdate2
- Vessel Info: 2003 466 Motoryacht In Michigan. Purchased July 31, 2020
- Has thanked: 4 times
I have the ZF transmission and electronic controller. At the helm, the lights on the transmission controls are always on. It’s not hurting anything, but just seems wrong. Does anyone have this condition and/or figured out how to get them to turn off?
Also, my engine sync and rudder gauge is not accurate. Has anyone solved this problem?
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Trans lights always on
- Promdate2
Where is the adjustment for the rudder located — back of gauge?
The trans light issue is different. I’m referring to indicators on the electronic controller at the helm. These lights should be on when the engines are keyed on. Problem is that they are on even when the engines are turned off.
The adjustment for the rudder angle gauge is done at the sending unit which is located at the rudders. You'll see a sender with an adjustable arm hooked up to one of the rudder arms or the rod connecting the two rudders together. The sender arm or the adjustable linkage hooked up to it can be adjusted to achieve the correct reading. Turn the wheel until the rudders face straight back. Have someone at the helm monitor the gauge while you make the adjustment until they let you know that the needle is centered. Barring a problem with the gauge, wiring or sender, you should be able to get a good adjustment.
- Promdate2
I have the Cummins 480ce with ZF electronic trans controller. The gauge package provides very little engine data and I’m considering sbmar electronic package. The Raymarine autopilot also shows Rudder angle and it seems to be accurate.
I’ll let u know what I find on Monday
