Crusader 350XL won't start.
- wingnut
- Vessel Info: 1996 Carver 325
Suddenly, I have no spark and no fuel at the injectors. Engine cranks normally. Everything I have done has made no difference. I have tried swapping the ECM and coil from the other engine. I replaced with new the ignition module in the distributor. I have no popped CB's on the engine, but I opened the CB box and and checked the function of all the CB's with a meter. I disconnected the main harness for the engine to look for any sign of damage or heat, it was normal, clean, undamaged. The fuel pump is working normally, with proper fuel pressure. I have also checked a lot of other wiring for security, damage, continuity, etc.. No spark and no fuel. I'm stumped.
Any input would be much appreciated.
- Has thanked: 602 times
Re: Crusader 350XL won't start.
Your batteries are all fully charged, yes.
- wingnut
Yes, the batteries are fully charged. I have been working alone, so hard to work the key and wiggle stuff at the same time. But, I will do that tomorrow when I have an extra pair of hands. I have worked pretty much every connector I can touch, but I certainly understand the logic of of having help to work the key at the same time. Thank you!!
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 24 times
km1125 wrote:Source of the post Do those engines have a crankshaft sensor? With neither spark or fuel, I'd suspect the ECU doesn't know the engine is spinning.
I agree about the ecu just not seeing what it wants to provide a fuel and spark order.
I am not totally sure ( been wrong before..lol ) but I don't think they have those sensors....gets it's reference from the distributor I believe unless there is an oil pressure switch involved as well. Early 90's GM mefi. Marine versions were stripped down for the most part.
Hopefully we hear back as to the cause etc.
- wingnut
It was the failed pickup coil assembly in the distributor. That can be replaced but requires pulling the distributor and disassembling the shaft. So I decided to replace the whole distributor. Ouch $$, but I feel better doing that as the old one is 30 years old and some corrosion after those 30 years. My bilge is bone-dry and kept clean, but we still operate in a damp environment so I think we all fight the effects. Perhaps to add my own insult to injury, I think I will replace that distributor on the other engine too. Overkill?? Maybe. I prefer to ere on the side of caution.
- wingnut
The batteries are one year old, and in good condition. Also in the slip hooked up to shore power. Either way, the engine spins very fast.
Bud37 is correct. There is no crank sensor, rotation is sensed thru distributor.
Also, from another marine mechanic: "check the tach while cranking for rotation, as the tack should at least come off the beg showing some RPM's." Doing that he said would prove the health of the pickup coil.
