STBD engine has a breathing problem?
Pha8
Vessel Info: 2002 Carver 346
Has thanked: 32 times
Been thanked: 5 times
Postby Pha8 » June 16th, 2025, 1:27 am
2002 Carver 6.2mx Mercruisers
Twin 6.2 mx Mercs, stbd engine has a loud "hiss"?? Not sure if it has a air leak (Vaccume) or filter is dirty? Port engine sounds normal.
Any thoughts?
Re: STBD engine has a breathing problem?
Postby km1125 » June 16th, 2025, 2:38 pm
Are your spark arrestors clean? If not, remove them and clean them both.
I'd be checking hose connections too. Perhaps a vacuum hose has become dislodged.
I'd also look into the IAC valve and it's associated "filter".
Postby bud37 » June 16th, 2025, 8:49 pm
Pha8 wrote:Source of the post 2002 Carver 6.2mx Mercruisers
Any thoughts?
Considering your other issues from the CO post may I suggest having a certified marine mechanic have a look at your boat and perhaps recommission it. This may give you an another experienced eye on things and perhaps notice something missed and save time hunting around.
A vacuum leak that loud would have the engine running poorly IMO.....could be the belt or one of the pulleys/idlers......check the inside of the belt for cracks in the ribs, if so scrap it and keep for a spare. By all means clean the flame arrestors anyway.
krawdad
Vessel Info: Carver 1999 405 Aft. 454 Horizon motors
Been thanked: 4 times
Postby krawdad » October 2nd, 2025, 5:45 pm
I had this happen recently, the starboard motor developed a "very loud" hiss which could be heard on the bridge. Even with the hiss the motor ran normally. Changed out the IAC and hiss is gone. A month later the Port engine did the identical same thing. Changed that IAC and hiss is gone,
