Volvo Penta Diesels Black Soot
- johnmbath
- Vessel Info: 2002 Carver Voyager 570 Pilothouse
During the initial Sea Trial, there was Black Soot covering the back of boat, swim step and cockpit area.
We assumed it was due to the engine surveyor pushing the engines to 2600 rpm's.
Recently, we made a 4 hour trip to channel islands, cruising at 1800 rpm's and found the Black Soot was again covering the back of boat.
Any suggestions what would be the cause?
John Bath
- Been thanked: 490 times
Re: Volvo Penta Diesels Black Soot
Is the bottom of the boat clean?
What is the wot rpm spec and what is your actual wot?
How old is the fuel?
- johnmbath
Bottom paint is new this June 2025.
wot rpm specis 2600 rpm, actual is 2500 rpm
600 gallons of new fuel added August 2025 to 100 gallons existing.
John
Injectors?
- ck36
- Vessel Info: 2002 Carver 450 Voyager, TAMD74P
- Has thanked: 17 times
- Been thanked: 4 times
Some notes: as part of my troubleshooting I pulled the injectors and had them pop tested at a great local shop (Seattle Injectors) - all were good and there was no charge. I also had a Volvo tech from Pacific Power Group help me with the install and also checked fuel pump timing (only 1 deg off). After removing the turbo you can look into the air side of the CAC and I noticed about 1-2mm of soot buildup but when I recorded temps they seemed ok and it's costly to pull the CAC so I'm not going to do anything there for now. I have an inexpensive boroscope that proved very handy for looking into coolers and cylinders. Great tool to have for troubleshooting. I also had a diver cleaning my neighbor's hull do a quick check of my hull to make sure it wasn't excessively fouled. It wasn't, but it is fouled enough that I can't get past 2500 RPM.
Go through your troubleshooting methodically and I'd highly recommend getting the Yachtdevice gateways so you can a better idea of what's going on with your engines.
