Sliding Window Sweeps
Been thanked: 248 times
Re: Sliding Window Sweeps
Postby mjk1040 » June 19th, 2017, 8:42 pm
Found this;
M-D Building Products 04267 17-Feet Storm Door and Window Replacement Weather-strip
Peel and stick, looks and works great.
Pulled out the old stuff on the rear sliding window, cleaned with alcohol, stuck the new on. I don't think you would wver get the stuff back into the rail it came out of unless you had an open end to slide it into.
Postby g36 » June 20th, 2017, 9:18 am
thanks for putting this update on here. got any pic or tip for installing this? i need to look at mine i know this needs to get done
Postby mjk1040 » June 20th, 2017, 5:38 pm
I removed the windows and pull the old moe hair seals out. Then I cleaned side tracks with alcohol and stuck the new moe hair on. Do not pull out the rail the window slides on. Just like new again. I do not think you could slide in new moe hair in the track you pulled it out of unless u took the window frame apart or notched the old track to slide the old style back in again. Good luck with urs, I'm happy mine now.
Dan1748
Vessel Info: 1989 Carver 3607 Aft Cabin
Postby Dan1748 » July 21st, 2017, 1:58 pm
Hello, Wondering where you got the replacement moe hair? Looks like mine has pretty much been destroyed by age and moss. The windows require herculean strength to open and close so I'm thinking new track inserts would help a lot. I'm assuming I'd have to scrape out the old grey fuzzy stuff that's there now and somehow affix new tracks with the fuzzy moe hair? Any insights appreciated.
Dan
Dan1748
Postby Dan1748 » July 21st, 2017, 2:08 pm
Whoops. Need to bone up on my reading skills. 04267 Didn't see that initially. Thanks
Users browsing this forum: Remery124 and 16 guests
